Temp gauge doesnt work after swap
Just finished a b16a swap on a crx. The temperature gauge isnt working anymore. What should i check or go over..thanks for the help.
The stock water temp sensor is located under the dizzy, you should have a single wire just laying in that general area under your dizzy. Youll know that its the water temp plug cause its a 1 prong female plug that goes right onto the sensor.
hth
Blaze
hth
Blaze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">The stock water temp sensor is located under the dizzy, you should have a single wire just laying in that general area under your dizzy. Youll know that its the water temp plug cause its a 1 prong female plug that goes right onto the sensor.
hth
Blaze</TD></TR></TABLE>
Yup, this is the coolant sending unit located next to the ECT. Make sure it's not broken, and that it's plugged in.
hth
TypeR15
Feb 24, 2004 12:29 PM
