caliper slide pins removal help
what is the proper way to do it. do i take out the rubber seal first or leave it.. I know to lube it with hightemp grease and lub and clean the rubber seal but does the rubber seal come off first and easy to put back on after?
Yes, you can pull the boot off first. If you're having trouble, take a small flathead and slide it between the caliper bracket and pin. Carefully pry the boot out of the little channel that it sits in. Don't clean the boot with anything too harsh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam268 »</TD></TR><TR><TD CLASS="quote">THE ONLY HIGH TEMP GREASE I FOUND ARE THE ONES FOR WHEEL BEARINGS.. ARE THOSE OKAY TO USE ON THE CALIPER PINS?</TD></TR></TABLE>
I normally use Brake Assembly Lube on the pins
PINKS
47
Nov 20, 2006 03:58 PM
EG2Driver
Jun 6, 2006 08:50 PM
SHystrdyGSRtdy
Aug 14, 2005 01:39 PM
Christopherian1982
Mar 28, 2005 06:56 AM
