Do used Cams need any kind of break in?
Old Aug 1, 2003 | 06:05 AM
haggar's Avatar
Default Do used Cams need any kind of break in?
Bought a pair of used cams for my LS motor. The head is all rebuilt with new OEM valvetrain(the cams are Crane #12s, rated OK for use with OEM valvetrain).
Question:
Since the cams are used(12k miles) do I need to do any special break in procedure?
I just assumed to assemble everything with the usual assembly lube?
Thanks,
Haggar
Old Aug 1, 2003 | 06:22 AM
1_bad_EF's Avatar
change oil after 500 miles or so.
Old Aug 1, 2003 | 08:11 AM
C1V1C's Avatar
Default Re: Do used Cams need any kind of break in? (haggar)
Once assembled, run it at 2000 rpm for 20 min, to make sure its properly lubed. Also change the oil after 100 miles.
redDAinteg
Jan 6, 2008 11:57 AM
ganjafarmer143
Dec 31, 2005 11:02 AM
slimbo
Mar 8, 2002 02:03 AM
Comptech98GSR
Mar 7, 2002 11:48 AM
