Need help B18C JDM Type R in 00 Si
Old Aug 1, 2003 | 01:16 PM
B18C 00 Si's Avatar
Default Need help B18C JDM Type R in 00 Si
Hi my name is David and i have a 2000 Civic Si with a JDM B18C Engine+Tranny. Only thing missing that i actually have is my JDM type R ECU. Thing is im still running on the Si ECU becuase i have the Si Harness. I need help in figuring out what i should do. Alot of people told me to get a USDM type R ECU and it should plug right up with my Si Wiring harness. Other people said i should have a harness custom made to fit the JDM type R ECU. Some advice would be appreciated. thanks.
Old Aug 1, 2003 | 02:27 PM
delacampos's Avatar
Default Re: Need help B18C JDM Type R in 00 Si (B18C 00 Si)
what year is your swap? my jdm b18c-r ecu is obd1 with obd2 connectors. so it fit in my 97 gsr perfectly. so, your shouldn't need anything to get the r ecu to fit.
Old Aug 1, 2003 | 03:24 PM
HXMan's Avatar
Default Re: Need help B18C JDM Type R in 00 Si (delacampos)
97 wire harness is different from 99-00.
You can buy a conversion harness(OBD2b to obd2a)....which I would recommend, or modify your stock harness. That will be a pain in the ***.
Old Aug 1, 2003 | 04:17 PM
B18PoweredCivic's Avatar
Get a Skunk2 Obd2b- obd1 jumper harness...Then just get a P28 ecu and have it chipped out with a Mugen Program for a b18c5...
mcvic
13
Dec 15, 2008 05:28 PM
94IntegraLs04
Aug 10, 2005 09:13 PM
B18C 00 Si
Aug 1, 2003 08:21 PM
B18C 00 Si
Aug 1, 2003 02:36 PM
