The Best Oil? Did some Research...
Old Sep 30, 2004 | 10:23 AM
LSVTEC 91 Civic's Avatar
Banned
Default The Best Oil? Did some Research...
I know, another oil thread, but I've been doing some research.
Check out the following links.
After reading this, I began looking for more sources.
http://www.amsoil.com/performa....html
Then I came across this:
oil. http://www.bestsyntheticoil.co...3.pdf
Valvoline SynPower 10w30 was rated better than Mobil1 SuperSyn, Castrol Syntec, Royal Purple, Redline, and regular Amsoil XL7500. Seems to me Valvoline SynPower is the best oil available at your local auto part stores. I'm a new Valvoline SynPower fan.
Old Sep 30, 2004 | 10:51 AM
timmy8151's Avatar
Default Re: The Best Oil? Did some Research... (LSVTEC 91 Civic)
If you want some more oil info check out the forums at:http://theoildrop.server101.com/ubb/ultimatebb.php
From what I've read Valvoline Synpower has good UOA numbers, but is also fairly expensive at ~ $4.70/qt.
For my 94 LS, I'm using Chevron Supreme 10W-30 dino that only costs $0.69/qt. Though it's an unexpensive oil, it has UOA's numbers better than more expensive oils.
Old Sep 30, 2004 | 10:57 AM
Daemione's Avatar
Take a look at AMSoil's 10w30 score, though - 15 points higher than the Valvoline Syn. And 34 points higher in the 5w30 weight . . . .
Old Sep 30, 2004 | 11:00 AM
EKCivicR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Valvoline SynPower 10w30 was rated better than Mobil1 SuperSyn, Castrol Syntec, Royal Purple, Redline, and regular Amsoil XL7500. Seems to me Valvoline SynPower is the best oil available at your local auto part stores. I'm a new Valvoline SynPower fan. </TD></TR></TABLE>
I think you better check again... Valvoline does not top AMSOIL 10w30 Synthetic. Although it does slightly edge out the Amsoil XL7500. C'mon.. now the XL7500 is a 7500 mi interval oil change or every 6 months. It's also formulated for new vehicles. Although the XL7500 is impressive... it does not top the Amsoil 10w30 synthetic formula which is for regular oil change intervals.
The graph shows Amsoil 10w30 scoring a 742 points vs. Valvoline SynPower 10w30 at 727 points...
So Valvoline still gets a
Old Sep 30, 2004 | 11:12 AM
Daemione's Avatar
Default Re: The Best Oil? Did some Research... (EKCivicR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKCivicR &raquo;</TD></TR><TR><TD CLASS="quote">So Valvoline still gets a </TD></TR></TABLE>
I wouldn't go that far. It's a damn good oil, and way easier to get a hold of than AMSoil.
Old Sep 30, 2004 | 11:14 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKCivicR &raquo;</TD></TR><TR><TD CLASS="quote">I think you better check again... Valvoline does not top AMSOIL 10w30 Synthetic. Although it does slightly edge out the Amsoil XL7500. C'mon.. now the XL7500 is a 7500 mi interval oil change or every 6 months. It's also formulated for new vehicles. Although the XL7500 is impressive... it does not top the Amsoil 10w30 synthetic formula which is for regular oil change intervals.
SynPower has +5 points over Amsoil XL7500 under 10w30... Synpower is also readily available at a local Autozone, Amsoil isn't. My original point was, Synpower is probably the best oil you're going to find at your local auto part store.
Old Sep 30, 2004 | 11:25 AM
EKCivicR's Avatar
SynPower has +5 points over Amsoil XL7500 under 10w30... Synpower is also readily available at a local Autozone, Amsoil isn't.</TD></TR></TABLE>
And your point is? I believe Valvoline is also a good oil and is widely available just about everywhere. But it does not top the Amsoil 10w30 Synthetic formula.
If Amsoil wasn't available to me, I definately jump on the Valvoline. But then again I've known this for a long time and have been using Valvoline before I switched over to Amsoil a few years back.
Most people don't use the XL7500... like I said it is for 7500 Mi or 6months interval oil changes. I change my oil every 3K mi. or 3 months, depends on which ever comes first.
Old Sep 30, 2004 | 12:53 PM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKCivicR &raquo;</TD></TR><TR><TD CLASS="quote">Most people don't use the XL7500... like I said it is for 7500 Mi or 6months interval oil changes. I change my oil every 3K mi. or 3 months, depends on which ever comes first.</TD></TR></TABLE>
The XL7500 is for shorter drain intervals than the standard AMSoil synthetic (which explains why it scores slightly lower) . . . . it's a complete waste to change any oil every 3k, much less something as good as a true synthetic. Heck, AMSoil advertises 25k mile drain intervals . . . .
Send it out to Blackstone labs, and ask for a TBN - they'll tell you the same thing.
Old Sep 30, 2004 | 01:54 PM
krazie1's Avatar
BANNED
Default Re: The Best Oil? Did some Research... (Daemione)
so all this talk is in regards to a used or broken in Build up or what??
like to know as I use regular Valvoline 10w-30
on a freshly or sort LS/VTEC
so just like to know what we are referring this all to
Old Sep 30, 2004 | 03:26 PM
EKCivicR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">
Send it out to Blackstone labs, and ask for a TBN - they'll tell you the same thing.</TD></TR></TABLE>
True.. actually the standard Amsoil Synthetic is suppose to go up to 25K Mi or 1 year intervals. Let me ask you something..? Do you track or race your car?
Do you not drive it out of the normal conditions? Do you at least beat on your car, ( I run my daily to 8500 rpms!) I suppose you want to race your car on the track for about 6months before changing the oil? I think not... so in thinking it is well worth your time to change your oil when it's dirty or wearing out to help keep it fresh. Believe me if you tell a customer buying a brand new car at the dealership and told them they didn't have to change the oil for 1 year chances are they probably look at you like your the dumbest person on earth!
Amsoil have been advertising 25K oil drain intervals for over 20-30 yrs now... is that a surprised? So in saying I guess you can do so.. but why? Meaning the long oil change interval thingy... Technology is good... but not great.
Lastly let's not forget that Amsoil accels in every other test category and not just the 4 ball wear test. Are we forgetting something here? It is still the best all around oil... period.
Old Sep 30, 2004 | 08:10 PM
RiceInspiredFireFighter's Avatar
well...this is my theory from the Beast from the East. I use Pennzoil 5w-30 ... UNLIKE my cousin ... the avid Valvoline user...I have had no leaks, drips, or loss of product. Maybe the 2 years in automotive technologies...back in highschool did pay off ^_^
Old Sep 30, 2004 | 08:45 PM
Diver's Avatar
Always make a very informed decision.
I thought I knew it all until I read this:
http://neptune.spacebears.com/....html
Old Sep 30, 2004 | 11:36 PM
XDEep's Avatar
what about contamination from blowby? i havent seen anyone bring this up before. unless you assume everyone has outstanding compression, everyone's oil will be contaminated at a different rate.
do the oil manufacturers consider contamination when suggesting these intervals?
if we know we are getting excessive blowby, how much sooner should you change the oil?
btw, oil turning dark from some contamination is normal.
Old Oct 1, 2004 | 04:39 PM
vtecmissle's Avatar
Default Re: The Best Oil? Did some Research... (XDEep)
why does the ranking score total seem better for the mobil one than the valvoline . Am i interpreting this wrong or what&gt; mobil one says 711 and the others are in the 600s
Old Oct 1, 2004 | 04:53 PM
RACEPAK's Avatar
Default Re: The Best Oil? Did some Research... (vtecmissle)
in israel they sell 5L of castrol txt 10-40 for $45
Old Oct 1, 2004 | 05:57 PM
dr_latino999's Avatar
Default Re: The Best Oil? Did some Research... (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">in israel they sell 5L of castrol txt 10-40 for $45 </TD></TR></TABLE>
Ouch man, that hurts.
Old Oct 1, 2004 | 06:44 PM
Mike K's Avatar
I run Honda 5w20. Why? Because I work at a dealership and it's free. My B16 88 hatch gets 3mpg more with 5w20 over 5w30. If I had an extremely modified engine, I would go back to my favorite high performance oil combo, which is uncommon but hate all you want... 3 quarts of OEM Honda 0w20 and 1 quart of Mobil1 5w30.
Old Oct 3, 2004 | 07:03 AM
UnKnownUser's Avatar
Default Re: The Best Oil? Did some Research... (Mike K)
What about redline oil?
Old Oct 4, 2004 | 06:48 PM
Banned
Default Re: The Best Oil? Did some Research... (LSVTEC ALLMOTOR DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">[url=http://www.bestsyntheticoil.com/amsoil/technical-data-bulletins/Specs-June-17-2003.pdf]</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC ALLMOTOR DC4 &raquo;</TD></TR><TR><TD CLASS="quote">What about redline oil?</TD></TR></TABLE>
SynPower was rated better from what I've read.
Old Oct 4, 2004 | 07:04 PM
Yah but is it enough to make a difference i dont think so....
Old Oct 5, 2004 | 02:44 AM
speedy400's Avatar
And where does Mobil 1 full synthetic stand in those ratings compared to Valvoline and Amsoil? Seems very popular and easy to find.
mxracer420
13
Apr 8, 2009 05:54 PM
bbhockey19
35
Jul 13, 2006 11:06 AM
tsdenny
Sep 30, 2004 01:13 PM
jeux
Jun 20, 2004 08:48 PM
B18Redline
Jun 10, 2002 02:40 PM
