ecu question pleeeease help
Old Sep 30, 2004 | 01:49 PM
96integralsgreen's Avatar
Default ecu question pleeeease help
my check engine light came on so i did the ecu code test and got code 92(obd2 ecu) so i looked up code 92 and it says Evaporative Emission Control System insufficient purge flow. what dose this mean? whats wrong with my car and how do i fix it? please help me. thanks
Old Sep 30, 2004 | 01:58 PM
Nameless RB26's Avatar
Default Re: ecu question pleeeease help (96integralsgreen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96integralsgreen &raquo;</TD></TR><TR><TD CLASS="quote">my check engine light came on so i did the ecu code test and got code 92(obd2 ecu) so i looked up code 92 and it says Evaporative Emission Control System insufficient purge flow. what dose this mean? whats wrong with my car and how do i fix it? please help me. thanks</TD></TR></TABLE>
It's a problem with your evap purge solenoid. This deals with fumes from the gas tank. That charcoal canister behind your motor, it needs to be purged and if it's not being purged of gasoline fumes, condensation will build up.
Go to honda and tell them to look at it. Or research it on google and fix it yourself. It's likely something simple to fix... unless you took it off your vehicle for some reason.
slowpokecivic
Feb 20, 2007 04:59 PM
brega3
Jun 30, 2003 03:43 PM
civic_sir94
Dec 30, 2002 09:23 PM
TurboedGSR
Aug 21, 2002 11:37 AM
