need HELP AutoMeter Tach
Old Sep 27, 2004 | 09:23 PM
eg6cusco10pt's Avatar
Default need HELP AutoMeter Tach
I just hooked up my tachmeter and it reads about 2-3k higher than my VAFC RPM readings also when i'm driving and reving it up it goes around 360 degrees in circle anyone knows what's wrong is it bad ground or bad connection for the green wire to the distributor??? help me out and thanks for looking.
Old Sep 28, 2004 | 08:06 AM
Default Re: need HELP AutoMeter Tach (eg6cusco10pt)
come on somebody had to experience this before...
Old Sep 28, 2004 | 08:16 AM
snatch's Avatar
Check you ground and also make certain that you soldered the wire connection for the signal. If you did it at the distributor or by the firewall, either way, make sure it's soldered, otherwise the connection can be bad and cause the tach to short out.
Old Sep 28, 2004 | 08:21 AM
Default Re: need HELP AutoMeter Tach (******)
thanks for the reply anymore is welcome
Old Sep 28, 2004 | 01:31 PM
problem fixed already thanks.
1234567899876543211230
Aug 15, 2006 11:52 AM
WhiteEG6
May 20, 2004 03:57 AM
its WANG yoO
Dec 9, 2003 09:19 AM
B20zvtecek
Jun 24, 2002 06:47 AM
