Turbo H23AI
Old Sep 29, 2004 | 11:04 AM
95ATEG's Avatar
Default Turbo H23AI
Im getting ready to buy the Turbonetics T3/T4 hybrid turbo kit...is there anything else i will need besides what comes in the kit?
The Kit Contents:
Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E)
Spearco Intercooler System
Powder-Coated Intercooler Piping
Silicone Hose / T-Bolt Clamps
Exhaust Manifold - high carbon cast-steel with ceramic coating
Fuel / Timing Controller (electronic fuel / timing management system)
Fuel Injectors
"Evolution" Wastegate Assembly
"Raptor" By Pass / Blow Off Valve Assembly
Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge
Should I keep the Raptor BOV?...Also I am buying an AEM High Flow Fuel Rail...should I get a High Flow Fuel Pump (Venom in mind) and High flow Fuel injectors (Venom again)?
Thanks phil
Old Sep 29, 2004 | 09:21 PM
PrettyLude's Avatar
is this a built motor you are putting it on? the raptor bov is an alrite to work with.
Old Sep 29, 2004 | 09:34 PM
95ATEG's Avatar
Default Re: (PrettyLude)
no its a stock motor...may be upgrading the fuel injectors and fuel rail and fuel pump after the turbo install but right now its stock.
lazyxazianxboi
Feb 16, 2007 01:47 PM
98civiccx
Nov 6, 2004 09:38 AM
dustineck
Mar 22, 2003 06:18 PM
