Crankshaft.Bearings???Sizes? Need help please.
Old Sep 27, 2004 | 05:29 AM
L_S_i's Avatar
Default Crankshaft.Bearings???Sizes? Need help please.
I´ve damaged up my crankshaft. If I send it to a machining shop to fix it I´ll need thiker bearings right? Were can I buy them? Thanks guys.
Old Sep 27, 2004 | 08:50 AM
EX-T's Avatar
Default Re: Crankshaft.Bearings???Sizes? Need help please. (L_S_i)
Honda. They have different clearances and they are distinguished by colors.
Old Sep 28, 2004 | 12:18 AM
L_S_i's Avatar
Default Re: Crankshaft.Bearings???Sizes? Need help please. (DSeriesBKilla)
That I know but do they have bearings for this kind of situation. I believe they dont have bearings for a machined crank or do they?
Old Sep 28, 2004 | 08:30 PM
AsianMullet's Avatar
they have all the colors which you should check to match your specs that your machining it down to
Old Sep 28, 2004 | 08:53 PM
Jim Truett's Avatar
Default Re: Crankshaft.Bearings???Sizes? Need help please. (EKchump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKchump &raquo;</TD></TR><TR><TD CLASS="quote">they have all the colors which you should check to match your specs that your machining it down to</TD></TR></TABLE>
The range isn't that large. You will need aftermarket bearings, either .25mm or .5mm undersize, to be determined by the amount of material the machine shop removed. The machine shop should be able to supply them.
Honda cranks are Nitrided (Heat treated) to reduce wear and increase durability. Personally if it was mine I would toss it and find a good used one.
Old Sep 29, 2004 | 01:42 AM
L_S_i's Avatar
Default Re: Crankshaft.Bearings???Sizes? Need help please. (Jim Truett)
yeah I think its better to get a new one, maybe I get one from raceeng or something good. Even if I have it machined the problem is that I dont trust the material without the nitril coating...maybe I´m dum... or maybe I´m not. If I chose one good crank what would you recomend to go with stock rods and pistons. Or what would you recomend to go for crank, rods and pistons(forged) to get a good setup?
Thanks for your help guys
I_eat_Rice
Jul 6, 2008 12:58 AM
egkyran
12
Jan 17, 2008 12:16 PM
SCRATCH
12
Jan 31, 2007 08:31 AM
l2yanE
Jul 23, 2005 09:10 PM
Geno
Oct 27, 2004 07:22 PM
