Car will not start!!!!!
Old Sep 29, 2004 | 06:14 PM
ToiletFetusSushi's Avatar
Default Car will not start!!!!!
My car just turns over and wont start.. Its getting spark and gas.. Ive tried replacing everything inside the distributer and checking all of the fuses and relays.. I dont know what to do next.. anyone have any suggestions?
Old Sep 29, 2004 | 07:33 PM
ViZ's Avatar
ViZ
Default Re: Car will not start!!!!! (ToiletFetusSushi)
check your timing. and what method did you use to check for fuel and spark?
Old Sep 29, 2004 | 08:23 PM
powertech's Avatar
first try spraying carb-cleaner or starting fluid in the throttle body. If the car starts than you know that you are not getting enough fuel.
Old Sep 29, 2004 | 08:29 PM
Timing is right. I tried carb cleaner and it dident work.. I took the spark plug wires out and watched it spark and you can smell gas when it turns over.. I also took the spark plug out and watched the gas squirt down.
Old Sep 29, 2004 | 11:57 PM
anyone else have a suggestion?
Old Sep 30, 2004 | 02:19 AM
eg6T's Avatar
compression,check your compression
Old Sep 30, 2004 | 07:14 AM
mycrxsi's Avatar
dont spray anything like starting fluid or **** into a honda motor, if it doesnt start normaly then it doesnt need to and should be looked at. check all your grounds and be sure everything is connected to your ecu good if you've done a swap. also check its getting fuel you should hear the pump kick on when you turn the key over.
Old Sep 30, 2004 | 09:12 AM
Default Re: (mycrxsi)
the fuel pump is being primed when the key is turned over. I did do a swap about a year ago. I have never had 1 problem from it though.. I may try adding another ground just for the hell of it.
davidzhou4893
10
Mar 18, 2014 08:53 AM
nandito
Nov 9, 2011 08:27 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
Boosted_CRX_507
Oct 9, 2008 02:35 PM
k24ej8
Sep 30, 2006 03:20 PM
