gsr timing problem
Old Oct 1, 2004 | 07:22 PM
fufu's Avatar
Default gsr timing problem
i am having a strange timing problem on my jdm gsr engine the engine is stock with bolt on parts such as intake exhaust and honda n-1 lightweight pulley when its idling its about 0 degree (i set the timing light to 0 and the red mark on pulley is above
the timing slot) but if i rev up the engine at about 2500rpm the timing is 16 degree which is right timing but if i dont rev the engine it go back to 0 degree also if i rev to 3000 rpm the timing mark jumps 0 or 16 degree or it dont flash frequent (i am guessing its missing or not firing) i decide to ask you guys before i change any parts
appreciate of your help
Old Oct 1, 2004 | 07:44 PM
Kamin's Avatar
Default Re: gsr timing problem (fufu)
timing is RPM related the faster the engine turns, the earlier a spark needs to happen so you get a complete burn. now does the engine run good or are you feeling a misfire?
Old Oct 2, 2004 | 09:29 AM
fufu's Avatar
at idling i put my distributor all the way toward firewall and only get 0 degree
my car is hard to start when engine is cold and use alot of gas
full tank of oct 91 gas last 370KM (not miles)
curiouser
Apr 3, 2008 10:45 PM
Rostr02
Aug 11, 2005 06:19 PM
fufu
Sep 19, 2004 04:21 PM
Pele
Sep 30, 2002 04:58 AM
Answer
Mar 24, 2002 07:53 PM
