Upper Ball Joint 6th Gen
Old Sep 27, 2004 | 03:57 PM
Conspiracy's Avatar
Default Upper Ball Joint 6th Gen
I just did my first DIY spring install....it didnt go very well. The sportlines I put on my stock struts dont fit back in the area I took my stocks out of. To get them in I decided to separate the ball joint...in doing so I striped both upper ball joints and ruined the thread on them. I need to know if the A arm on the 6th gen has removable ball joints or if they are welded to the a arm. Any help is greatly appreciated.
Old Sep 27, 2004 | 07:34 PM
Conspiracy's Avatar
Default Re: Upper Ball Joint 6th Gen (Conspiracy)
help a brotha out plz
Old Nov 11, 2004 | 08:47 AM
-Bionic-'s Avatar
Former Sponsor
You should be able to separate them. However, you might as well replace the whole control arm, since Honda apparently doesn't sell the upper ball joint by itself. Hope it helps.
EDIT: What car are we talking about? I referring to a 6th gen accord.
Old Nov 11, 2004 | 10:33 AM
j_kevin_ca's Avatar
Default Re: Upper Ball Joint 6th Gen (-Bionic-)
is the control arm removable too??
Old Nov 11, 2004 | 10:00 PM
suspendedHatch's Avatar
Default Re: Upper Ball Joint 6th Gen (j_kevin_ca)
Might as well get a camber kit that goes in place of the upper ball joint, like one of the SPC kits. Remove the locking ring, press the old ball joint out, and press the alignment kit in.
Yes the upper control arm comes out easily. On a 5th gen Civic anyway.
Old Nov 11, 2004 | 10:35 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_kevin_ca &raquo;</TD></TR><TR><TD CLASS="quote">is the control arm removable too??</TD></TR></TABLE>
Yep.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">Might as well get a camber kit that goes in place of the upper ball joint.</TD></TR></TABLE>
Good advice, especially if the car is lowered or if you have future plans to. In either case, it will cost you about the same to get a camber kit, as it would to buy a OEM Honda part.
Old Nov 12, 2004 | 05:32 AM
EE_Chris's Avatar
6th gen Civics have the upper ball joint pinned in - to replace it, is to replace the entire arm.
PreludeBC420
Aug 16, 2016 01:44 PM
Nate091
Jul 30, 2012 09:55 PM
1slowvtec
Apr 4, 2006 06:58 PM
staticrex
Nov 3, 2005 12:22 PM
c mak
Sep 13, 2004 04:51 AM
