B18c5 swap Need help!!!!!????
Old Oct 1, 2004 | 11:34 AM
highboostb18c1's Avatar
Default B18c5 swap Need help!!!!!????
ok heres the setup
1996 honda civic hb cx
2000 itr swap
96-98 dx harness w/vtec wired to ecu
obd2 A to Obd2 B jumper harness
vtec controller
and heres the problem.
when the car gets up to about 2500 rpmds it seems like its hitting the rev limiter. it won't go past 2500. it seems like its getting a fuel cut, any ideas?
Old Oct 1, 2004 | 11:51 AM
Redsun's Avatar
What vtec controller?
What ECU are you running?
Old Oct 1, 2004 | 11:58 AM
Default Re: (Redsun)
apexi vtec controller
99-00 civic SI ecu
Old Oct 1, 2004 | 12:14 PM
Redsun's Avatar
Ok, i'm no expert in the OBDII's but is the VAFC set up properly?
A guy i know had a similar problem but at 7,000rpm with '98 ITR in '90 CRX.
He managed to fix it by getting a Spoon ECU ( so he said).
My advice is to go OBDI chipped P28 with ITR program.
Old Oct 3, 2004 | 09:48 PM
JDMorgan's Avatar
to be 100% honest i never touched an obd car. i own an obd0 b18c1 90 integra. but might aswell try to help. what codes are you throwing? did you wire the vtec oil pres properly?
bobbyboy545
Mar 19, 2024 12:43 PM
SingleCamin
10
Mar 10, 2011 02:00 PM
dustrag
Jun 17, 2004 10:04 AM
rice4life
Apr 14, 2004 05:11 PM
EEK
Aug 24, 2002 01:54 PM
