Vtec engine swap to NonVtec & Harness questions??
Old Sep 26, 2004 | 10:50 PM
PaChiLa Leader's Avatar
Default Vtec engine swap to NonVtec & Harness questions??
Do i have to change my cabin harness to an Vtec cabin harness in order to swap a Vtec engine in?
my car is OBD2V2 NonVtec and the engine is OBD2v1 Vtec
thanks
Old Sep 27, 2004 | 01:02 AM
junek00's Avatar
Default Re: Vtec engine swap to NonVtec & Harness questions?? (PaChiLa Leader)
Your using the vtec(engine) wiring harness right? If so just plug and play!!
Old Sep 27, 2004 | 04:00 AM
civic-4-ges's Avatar
Default Re: Vtec engine swap to NonVtec & Harness questions?? (junek00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junek00 &raquo;</TD></TR><TR><TD CLASS="quote">Your using the vtec(engine) wiring harness right? If so just plug and play!!</TD></TR></TABLE>
Re-read his post....
YOur going from OBD2B car to an OBD2A engine?? You can do it just fine, you either need to run an OBD2B ecu, or convert to OBD1 and run P28
As far as your wiring, you will need to add the pins for the Vtec Selenoid, vtec oil pressure sensor, and knock sensor, which you will also have to purchase unless its on the engine you are buying.
The plugs are not easy to come by in all cases, you would be best to swap the entire harness over. It is actually a very easy process, since you are replacing the entire engine. I was able to replace mine in about 2 hours, including taking the intake manifold on/off.
Old Sep 28, 2004 | 07:52 PM
Default Re: Vtec engine swap to NonVtec & Harness questions?? (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">
The plugs are not easy to come by in all cases, you would be best to swap the entire harness over. It is actually a very easy process, since you are replacing the entire engine. I was able to replace mine in about 2 hours, including taking the intake manifold on/off.</TD></TR></TABLE>
YES YES the engine came with the complete engine harness (OBD2a) but my cabin harness is OBD2B nonvtec so i would probably need to wire up the knock sensor, oil puressure sensor and vtec solenoid, right? but how? from the engine bay and extend wires from there?
Old Sep 29, 2004 | 03:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaChiLa Leader &raquo;</TD></TR><TR><TD CLASS="quote">
YES YES the engine came with the complete engine harness (OBD2a) but my cabin harness is OBD2B nonvtec so i would probably need to wire up the knock sensor, oil puressure sensor and vtec solenoid, right? but how? from the engine bay and extend wires from there?</TD></TR></TABLE>
Yes, you are correct
The only other thing is the IACV. You will have to convert it from 3 wires to two. Basically you are just cutting a wire, and putting a new plug on the end
Old Sep 29, 2004 | 06:57 AM
The only other thing is the IACV. You will have to convert it from 3 wires to two. Basically you are just cutting a wire, and putting a new plug on the end </TD></TR></TABLE>
don't quite understand here
can you show me with pix
i know the IACV 3 to 2 wire thing .. read it somewhere but i thought that was only for civic hybirds with b-series engine
Old Sep 29, 2004 | 07:09 AM
I don't have a pic, but obd2a/b non v-tec ( D16y7) has a 3-wire IACV, manual or auto tranny
OBD2A/B Manual vtec (d16y8) has a 2 wire IACV
The difference is very minor, but you still need a different connection
Old Sep 29, 2004 | 08:24 AM
i think this is what you are talking about
All 96-01 B-series & 96-00 M/T SOHC Vtec (EX+HX) enginess use a 2 wire IACV.
so guess i don't need to worry about that at all
PaChiLa Leader
Nov 8, 2008 10:52 PM
hatch b16a guy
Jul 15, 2007 08:25 PM
eg_junior
Jan 16, 2007 06:24 PM
HaNsElBaDaSs
Oct 19, 2006 11:17 AM
JDM_Frijoles
Sep 2, 2006 11:41 PM
