depinning distributor
Old Oct 2, 2004 | 12:22 PM
6shootahorsenamedtrigga's Avatar
Default depinning distributor
Okay I have an obd2 distributor that I need to change the plugs to obd1. I could cut the wires but I would rather depin the connectors. Has anyone does this? Is the process the same for depinning ecu connectors? If it can't be done I'll just cut wires.
Old Oct 2, 2004 | 12:26 PM
Default Re: depinning distributor (mphinesee)
okay i see that it can be done.....but how do u repin it? same way as ecu?
Old Oct 2, 2004 | 01:05 PM
neone?
Old Oct 2, 2004 | 11:43 PM
Default Re: depinning distributor (eda6 hatch)
yeah thanks...i figured it out...heres how i did....obd1---> pulled out white plastic thing...bend pins against the securing tabs and pulled out wire.....for obd2 pulled out the plastic piece its green instead of white...then use a small screwdriver to lift the securing tabs and pull wires out...pretty easy...only thing is the obd2 pins that would go to the obd1 two pin connector are two big so i just said screw it and swapped the pins onto the wires...oh also for the two pin connector pull out the back plastic piece,,,lift tabs and pull wires.....avoided the cut wires/solder/electrical tape/shrink wrap look
nikkarocky
Texas -OK -LA (Sales)
12
May 3, 2007 10:11 PM
ham
11
Dec 24, 2006 10:14 AM
92EG8
Dec 3, 2006 06:41 PM
Scubster
Sep 28, 2004 11:29 PM
Turboteggy
Jul 21, 2004 08:40 AM
