HELP Gas cap problem or CEL after Fill ups????
Old Sep 27, 2004 | 01:15 AM
scootrrydr's Avatar
Default HELP Gas cap problem or CEL after Fill ups????
My 98 accord has the check engine light every time I fill up. I tighten three clicks too. Then after about 3 days the cel shuts off...???? I went to the local shop and the code comes back to Catalytic convert. Should I replace the gas cap? the cat convert? sensors?
Old Sep 27, 2004 | 08:53 AM
EX-T's Avatar
Default Re: HELP Gas cap problem or CEL after Fill ups???? (scootrrydr)
I would start with the cap b/c that is going to be your cheapest route.
Old Sep 27, 2004 | 10:36 AM
JimBlake's Avatar
Get the code #??
A gas cap that's not airtight would set P1456.
A bad catalytic converter would set P0420.
I had AutoZone read a code for me once, they read the actual code # OK. But then the guy came up with an amazingly creative story for WHY it came up with that error.
Old Sep 27, 2004 | 12:55 PM
scootrrydr's Avatar
Default Re: HELP Gas cap problem or CEL after Fill ups???? (JimBlake)
autozone did read the p0420 code for bad cat convert. but why does the cel shut off after 3-4 days after filling up on gas?
should I worry... or just get a new convert installed?
Old Sep 27, 2004 | 01:21 PM
JimBlake's Avatar
Got less than 80k miles? Emmissions system warranty is 8yr/80k imles. Maybe it'll be free - at least it's worth a phone call to the dealer to ask.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scootrrydr &raquo;</TD></TR><TR><TD CLASS="quote">autozone did read the p0420 code for bad cat convert. but why does the cel shut off after 3-4 days after filling up on gas?</TD></TR></TABLE>That part is pretty strange. But just as one dumb idea... Try filling the tank not all the way, the next few times. I'm taking a wild guess that if you try to overfill your tank you saturate the charcoal in the EVAP canister. Maybe that leads to over-rich running for a little while?
If I had to pay $$$ for a new catalytic converter, I'd want to be pretty sure that it's really the problem. I wouldn't buy a gas cap unless it was throwing P1456.
Old Sep 30, 2004 | 07:56 PM
PH3593A's Avatar
My CEL is on after I filled up with 91 octane. I normally run 87, but the pump was out of order. Is this normal? My CEL has been on since Saturday.
Old Sep 30, 2004 | 09:20 PM
Donkey85's Avatar
Default Re: HELP Gas cap problem or CEL after Fill ups???? (PH3593A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PH3593A &raquo;</TD></TR><TR><TD CLASS="quote">My CEL is on after I filled up with 91 octane. I normally run 87, but the pump was out of order. Is this normal? My CEL has been on since Saturday. </TD></TR></TABLE> no something else would have to be your problem because switching octane wouldn't cause a cel
Old Sep 30, 2004 | 09:43 PM
huyvu90's Avatar
I never knew a bad gas cap can light CEL.
I saw a car with a rag instead of a gas cap.
Old Sep 30, 2004 | 09:55 PM
Donkey85's Avatar
Default Re: (huyvu90)
yeah most newer cars will do that cause its "not emission friendly to have gas fumes going into the ozone"
elnoyl
Honda Civic (2006 - 2015)
Aug 29, 2021 07:26 PM
dgarlotti
Feb 26, 2013 05:44 AM
bopbop93030
Nov 8, 2008 03:02 AM
northworm
Nov 10, 2007 09:24 AM
BlackEJ6
Jan 13, 2006 03:02 PM
