Stupid Question - Automatic Tranny Fluid Dipstick?
Old Oct 9, 2004 | 07:54 PM
B18C_EJ8's Avatar
Default Stupid Question - Automatic Tranny Fluid Dipstick?
Before I get flamed, let me explain that of the 6 or 7 cars I've owned, the 1994 Civic LX I just bought is the only one with an automatic transmission. None of my family drives an auto, and neither does my girlfriend...
Okay... Question... The car shifts sortof hard into 2nd gear, so I was thinking of changing the fluid... I was looking it over, but didn't see anyplace to fill it, nor did I see a dipstick to check the fluid. Maybe I just wasn't looking hard enough? Can someone explain this oh-so-difficult concept to me? LOL
Thanks...
Old Oct 9, 2004 | 07:58 PM
B18C_EJ8's Avatar
Default Re: Stupid Question - Automatic Tranny Fluid Dipstick? (B18C_EJ8)
Damn... Need to search BEFORE posting... Found a pic of the dipstick location... I'll check it tomorrow... Couldn't, however, see where to fill it. Is the spot the same as on a manual? (on the side)??
Old Oct 10, 2004 | 03:19 AM
ryanstev's Avatar
You fill it through the dip stick hole.
EDIT: if the ATF is very dirty, you should replace the oil using a machine, draining it manually will only get around 60% of the old stuff out.
Old Oct 10, 2004 | 07:07 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You fill it through the dip stick hole</TD></TR></TABLE>
Are you serious???
Old Oct 10, 2004 | 05:49 PM
ryanstev's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Are you serious??? </TD></TR></TABLE>
That's how you do it on alot of Hondas, the dipstick is very short and has a hole of around 1 inch diameter.
Old Oct 11, 2004 | 07:23 AM
JimBlake's Avatar
Default Re: (ryanstev)
Filling thru the dipstick hole is pretty common, not just on Hondas. It's actually more difficult on some non-hondas, with the 1/4" tube for the dipstick.
When you drain/fill, the torque converter doesn't drain, so you're only changing about 1/3 or 1/2 of the fluid. If the fluid's dirty or smells burnt, do maybe 3 drain/fills, drive it around in between. I've heard(?) that Honda auto-trannys don't really like to be flushed with a machine.
Old Oct 11, 2004 | 11:31 AM
.dave's Avatar
i HAS questions ?
Default Re: (JimBlake)
Get one of those metal funnels with the 18" of flexible tubing coming off the bottom from Pep Boys/Autozone etc. Check the drain plug for metal shavings too, or you'll be stuck pushing your car to back out of a parking spot one day.
bhomar
Acura TL, RL & ZDX
Oct 25, 2011 03:23 PM
jetspeedz
Transmission & Drivetrain
Sep 10, 2008 08:29 AM
jolt-tsp
Dec 2, 2005 07:33 AM
egyolk
Apr 29, 2005 12:33 PM
jiGGaMein
Aug 16, 2002 01:20 PM
