Coolant Temp problem
Old Oct 5, 2004 | 02:52 PM
superstud's Avatar
Default Coolant Temp problem
everytime i turn my heat on, my temp gauge drops. the more heat, the lower the gauge. the air blowing also doesn't get overly hot either. really need to get this fixed for winter. any ideas?
Old Oct 5, 2004 | 03:42 PM
Super Chicken's Avatar
Default Re: Coolant Temp problem (superstud)
Got thermostat?
Old Oct 5, 2004 | 09:08 PM
PrettyLude's Avatar
check the evap core
Old Oct 5, 2004 | 09:13 PM
litshoot's Avatar
Default Re: (PrettyLude)
no thermostat will make the engine run hot believe it or not. how many degrees does the engine temp drop. approx. there will be some drop depending on the size of the heater core.
Old Oct 5, 2004 | 09:21 PM
drdisco69's Avatar
Default Re: (litshoot)
No thermostat will make the engine hot but the coolant cold. Throw a thermostat in for poops and hahas. Pretty common to have one stuck open.
Old Oct 5, 2004 | 10:19 PM
superstud's Avatar
the thermostat is fairly new. i thought that was the problem so i already changed that.
degrees dropped? i don't know, but normally the needle is about 1/8inch below halfway. if the heat's on full, it'll go down well below a quarter.
Old Oct 8, 2004 | 08:43 AM
superstud's Avatar
i really need help with this issue, any other ideas?
Old Oct 8, 2004 | 10:20 AM
1bad-eg's Avatar
Default Re: (superstud)
That still sounds like a stuck thermostat to me. Are you running an aftermarket or OEM thermostat? What kind of car?
Old Oct 10, 2004 | 11:58 AM
superstud's Avatar
Default Re: (1bad-eg)
its an aftermarket replacement thats supposed to open at the same temp as a stock one. it's in a 95 integra (b18b1, obd1).
could there be an air lock in the heater core or something? i can't figure out why the temp gauge would drop so much when the heat goes on.
Old Oct 14, 2004 | 12:44 PM
Death_to_Thieves's Avatar
does your car overheat? I had this problem and my air would blow cold and it would cause my car to overheat. changed thermostat and nothing. Turned out to be my headgasket. Hopefully this isnt your problem but its something to check out. good luck man
bandit080000
Dec 7, 2008 08:25 PM
typeRobtypeS
Nov 20, 2005 08:02 PM
superstud
Mar 14, 2004 08:54 PM
DR. ON POINT
Aug 11, 2002 07:42 PM
delSolLS
Jan 16, 2002 01:06 PM
