Miss fire problems! help!
Old Oct 6, 2004 | 09:11 AM
Firewerks's Avatar
Default Miss fire problems! help!
Ok i just finished installing the Edlebrock intake manifold on a b16a2, now the first time i started the car since the install i noticed the engine was running hard and i had the CEL flashing miss fire. now i check my plugs (good) i check my wires (also good) and just replaced the cap with an msd pro cap and external coil hoping this would remidy the problem. after installing i started it up and still no change. i also noticed when i bring the throttle up to try increase the voltage going to the cap, it sticks at what ever RPM i bring it to!
im totally lost and running out of ideas.
Anyone?
thanks
Old Oct 6, 2004 | 01:55 PM
IVI's Avatar
IVI
Default Re: Miss fire problems! help! (Firewerks)
did you put the plug wires in the right firing order? i would get the firing order of your motor and double check this first.
Old Oct 6, 2004 | 08:10 PM
ekgcool's Avatar
Be sure all manifold bolts/nuts are tightened. You may have left one or all a little loose. Triple check them I had an almsot similar problem, but the car only idled at 3k rpm. I retightened all bolts/nuts 3 times. Fixed the problem right away. Also check the throttle body bolts.
young_tuner
Dec 1, 2009 06:39 PM
RedSuns86
Oct 17, 2009 12:38 PM
dcsports
Dec 7, 2008 06:54 PM
arospeedintegra
May 30, 2008 01:20 AM
emooheo
Aug 18, 2007 11:27 AM
