overheating prob!!!
Old May 26, 2008 | 08:10 AM
boostedcivic37343's Avatar
Default overheating prob!!!
ok i have a 99 civic b16 with arp head studs and i can drive the car around for about and hour and it starts overheadting i let it cool down and check the coolant and some of my coolant is gone i have change the t-stat, radiator,check'd compression and it was 150,150,136,135.there r no leaks ne were no water in my oil from what i can tell and no oil in my water and i have just changed the headgasket about 2 months ago..oo yea and when it start get hot it idles up and down,and its also a new radiator cap.i am stump and in need of help bad lol
Old May 26, 2008 | 08:25 AM
mkw1's Avatar
Default Re: overheating prob!!! (boostedcivic37343)
the coolants going some were if you say it losing some. my guess is its burning it. there is a test u can do to check for hydrocarbon's in your coolant.
Old May 26, 2008 | 08:38 AM
Default Re: overheating prob!!! (mkw1)
how can i run this test
Old May 26, 2008 | 11:53 AM
h22civic88's Avatar
You had two cylinders side by side that were low and about the same compression... Thats almost always the head gasket :/
Old May 26, 2008 | 07:14 PM
khooper's Avatar
this might help you distinguish the cause of the overheating.
the temperature gauge will swing back and forth until the entire system is warmed fully. This is because you keep introducing "cold" coolant from the radiator into the engine, rapidly cooling it. When the temp falls enough, the thermostat closes, and the temp goes back up, repeating the cycle. This is due to a valve which lets you get heat before the thermostat opens up. It keeps the warm coolant in the engine *and heater* when the thermostat was closed.
________________
Autopartswarehouse
Old May 28, 2008 | 03:13 PM
Default Re: overheating prob!!! (khooper)
well i changed my head gasket and it still runs hot
Old May 28, 2008 | 04:13 PM
michaeljenkins's Avatar
is the ecu throwing any cells?
Old May 28, 2008 | 05:00 PM
TwinOptiX's Avatar
If the engine overheated there's the possibility that the head has warped. Therefore your new head gasket won't seal properly and you'll burn coolant and continue to overheat. Your compression test numbers lead me to believe that's the case.
Just something to keep in mind.
BigJerm333
12
Aug 5, 2014 08:01 AM
oneludesol
Engine Management and Tuning
Feb 26, 2010 12:45 PM
oneludesol
Jan 4, 2010 07:47 AM
94-integra-ls
Mar 30, 2008 08:22 AM
b00sted4dr
Oct 12, 2006 10:19 PM
