97 civic si canadian cluster problem
Old May 30, 2008 | 02:45 PM
jdm2envy's Avatar
Default 97 civic si canadian cluster problem
i have a si cluster in my coupe....the rpm everything works fine..but the kph keeps jumping....once in a while it start working properly then it would start jumping around agian...what can be the problem ??
Old May 30, 2008 | 08:29 PM
inspyral's Avatar
Are you having any other electrical problems? The Canadian Si is the same as the US EX if I'm not mistaken, and you should have a VSS/ALT fuse in your under-dash fuse panel. If that fuse is blown, it can cause an erratic speedometer, as well as affect your alternator/electrical system. I would check that first and go from there.
Old May 31, 2008 | 02:56 PM
jdm2envy's Avatar
yes it affect the electrical system. We just put a new alternator & it works fine but after like an hour the motor died! I think theres something wrong with the wirings, battery, fuse, or distributor..
Old May 31, 2008 | 06:48 PM
jdm2envy's Avatar
i just got home from my buddys shop! finally.. its a freakin 7.5 fuse alternator sensor... we changed the fuse & it works fine..... also the cluster is good now..thanks inspyral
Old Jun 13, 2008 | 07:00 PM
caraudiofaq's Avatar
Default Re: (jdm2envy)
i changed my fuse and it is still not charging?
agustintorre
Sep 14, 2012 06:55 PM
GSREXMan
Apr 14, 2009 01:22 PM
88aeFC3S
Aug 4, 2008 12:41 PM
helpmycivic
Dec 12, 2006 10:53 PM
mark2379
Sep 8, 2006 11:46 AM
