Problems with Speedometer after New Tranny Install.............
Old Aug 26, 2004 | 02:17 PM
Bulldogg83's Avatar
Default Problems with Speedometer after New Tranny Install.............
OK, so yesterday I installed a JDM GSR tranny with LSD into my 2000 Si that has a built b16 block. The tach works, but the speedometer does not work at all. I have already replaced the VSS today and it still doesn't work as well as checked the Alternator/SP Fuse under the dash and it is fine. I checked the pins on the clip that attaches to the VSS and all the pins are in place. I am running out of ideas and wondering if anyone can possibly help me out.
Old Aug 27, 2004 | 06:18 AM
AVATAR's Avatar
Default Re: Problems with Speedometer after New Tranny Install............. (Bulldogg83)
bump . . . no one knows ?? !! ??
Old Aug 27, 2004 | 06:31 AM
Vaans's Avatar
Default Cowbell
Hey Avatar, I like your sig.
Why dont you come lay that cowbell down right now...with us....together.
100th
Old Aug 27, 2004 | 07:30 AM
AVATAR's Avatar
Default Re: Cowbell (Vaans)
LOL the cowbell definately doesnt get the credit it soo rightly deserves.
Old Aug 27, 2004 | 03:54 PM
Bulldogg83's Avatar
Default Re: Cowbell (AVATAR)
UPDATE:
Took the VSS out of the tranny and cleaned it with parts cleaner/blowed it off with air, then also blew out the plug and rechecked all of the pins. Plugged it in and bam! It worked. I guess something was messing with the connection between the plug and the VSS. Everything is gravy now. Thanks for the replies!
Old Aug 28, 2004 | 12:06 PM
frostcivic's Avatar
Default Re: Cowbell (Bulldogg83)
where is the plug on the tranny?
Old Aug 28, 2004 | 05:19 PM
Bulldogg83's Avatar
Default Re: Cowbell (frostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostcivic &raquo;</TD></TR><TR><TD CLASS="quote">where is the plug on the tranny?</TD></TR></TABLE>
the VSS plug is on the back/top/right side of the tranny if you are looking at it from the front of the car.
Delano5050
May 5, 2007 08:52 AM
Bulldogg83
Aug 27, 2004 03:52 PM
jazz215
May 3, 2004 09:25 PM
