Help! ECU Problem
Old Aug 30, 2004 | 08:24 AM
hybrid_vtec's Avatar
Default Help! ECU Problem
I just recently had my P75 ECU chipped and now I get a check engine light but no codes and I can not rev past 3K! A J1 jumper, 20pin IC chip and a 28 pin IC chip w/ socket was installed! A 10K ohm resistor was sent to me but couldnt be installed b/c there is no location for it! All intents face towards the ECU plugs and the soldering is in good condition, so I dont know what else it could be! Somebody help me out with this!
Old Aug 30, 2004 | 10:15 AM
HRTuning's Avatar
Default Re: Help! ECU Problem (hybrid_vtec)
What was the chip programmed with?
Old Aug 30, 2004 | 10:18 AM
Default Re: Help! ECU Problem (HRTuning)
I dunno!
I have a P75 OBD-1 ECU! Chipping kit from Hyperducktuning
J1 jumper wire
20pin IC chip
28pin IC chip w/ socket(Skunk2 and PYR program)
I switched out chips and the same problem persists!
WTF could it be!
Modified by hybrid_vtec at 11:38 AM 8/30/2004
Old Aug 30, 2004 | 12:18 PM
HRTuning's Avatar
Could be any one of those parts or you could have done a bad job of soldering them in and messed something up... Track down the problem... If you need to use the ECU remove J1... That will run the stock program again...
Old Aug 31, 2004 | 04:49 AM
I know its not the solder, just me I work in a Calibration LAB and one of the 2M(microminature repair) guys did it for me, and we already checked that by putting it under the microscope!
Old Aug 31, 2004 | 12:46 PM
bump for help!
Old Sep 3, 2004 | 05:27 AM
Anyone else have any ideas!
Old Sep 3, 2004 | 08:20 AM
R-Toyz.com's Avatar
pm me
Vtec140
Oct 3, 2017 02:15 AM
hybrid_vtec
Sep 3, 2004 08:19 AM
100whplusperliter
Aug 9, 2003 11:35 PM
Mr. Softee
Jul 23, 2003 01:11 AM
tegsol1
Feb 12, 2003 05:13 PM
