uberdata, tps configuring?
Old Aug 27, 2004 | 11:54 PM
gldndrgn14's Avatar
Default uberdata, tps configuring?
hi. i was wondering for you uberdata users out there, is there a setting so you can reconfigure the voltage for the tps to work correctly? like if you are using itbs with the motorcycles tps instead of the oem? i couldnt find anything on the pgmfi.org or clubboost.com. also i have the uberdata 1.7 beta and went through it but couldnt find anything. so hopefully there is someway to do it that i have not found yet. any help would be much appreciated.
Old Aug 28, 2004 | 09:02 AM
non-VTEC's Avatar
Default Re: uberdata, tps configuring? (gldndrgn14)
there is no way you can modify the desired voltage for the TPS in uberdata....you need to play around with your TPS sensor to get it as close as possible....it probably will never be perfect but close......
cleansi
Engine Management and Tuning
Jan 26, 2010 08:42 AM
JUN_H22A
Jan 12, 2006 09:25 AM
ActiveAero
Aug 15, 2003 07:40 PM
gsr squirrel
Mar 26, 2003 11:51 AM
