Less turbo lag on high compression?
Old Sep 1, 2004 | 07:59 AM
mellowboy's Avatar
Default Less turbo lag on high compression?
Is this true or not? Can someone exlpain to me how this works? I always thought that having high compression turbo set up doesn't lag as much as lower compression. So fill me in with some knowledge!
Old Sep 1, 2004 | 10:44 AM
kettnerc's Avatar
It's somewhat true. How fast a turbo spools has to do with two things (as far as I know). The first is the amount of air that is going through the engine. THe more air per second, the faster the turbo will spin. The second is heat. The hotter it is, the more it'll spin the turbo.
Whether or not a higher compression engine pushes more air through at a given RPM than a lower compression one, that's up to a lot of other factors I think.
Old Sep 1, 2004 | 01:02 PM
StyleTEG's Avatar
Default Re: (kettnerc)
Higher compression pistons do create a stronger vacuum, and create a more complete burn (resulting in an increase in exhaust gases).
It will help you spool faster.
SiRLudeVtec
Mar 21, 2005 10:07 AM
hoggy
Jul 12, 2004 11:12 AM
Doug684
Dec 30, 2003 09:59 AM
MUGENTYPER
Feb 6, 2002 06:31 AM
