Just making sure. How do I use a compression tester?
Old Aug 30, 2004 | 08:12 PM
2SlowDC's Avatar
Default Just making sure. How do I use a compression tester?
I got a compression tester to see if my ringlands are gone. directions say remove the spark plug screw in the compression tester and let the engine crank for at least four compression strokes or until the compression reading stops rising? so does that mean turn on the car? the directions are specified for a carburated car so it says somthing about leaving the carburetor throttle plates to the wot position?
This is on a B18b. so heres what i got so far:
remove spark plug(1 at a time per test)
screw in tester
start car? and let the needle stop?
depressurize
repeat step for each cylinder
Old Aug 30, 2004 | 08:17 PM
mmuller's Avatar
Mad Scientist
Default Re: Just making sure. How do I use a compression tester? (lsVtec...)
you need to disable the fuel system or injectors so that they wont spray fuel.
take all the spark plugs out to do the test.
test it when the car is warm
hold the throttle plate open
crank around 7 times
Old Aug 30, 2004 | 08:21 PM
2SlowDC's Avatar
Default Re: Just making sure. How do I use a compression tester? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you need to disable the fuel system or injectors so that they wont spray fuel.
crank around 7 times</TD></TR></TABLE>
How do I "crank around 7 times?"
So I remove all the spark plugs at the same time?
and somehow hold the throttle plate open
Old Aug 30, 2004 | 08:29 PM
2SlowDC's Avatar
oh yea, is there a simple way to disconnect the injectors or do i havve to disconnect each one by the clips?
Old Aug 30, 2004 | 08:39 PM
2SlowDC's Avatar
K never mind&gt; thx 2 c-speedracing.com and h-t
Old Aug 30, 2004 | 08:40 PM
mmuller's Avatar
Mad Scientist
Default Re: (lsVtec...)
take out the main relay or ecu fuse
hold the gas pedal down while your cranking
crank around 7 times= turn the engine around 7 times
fakeownzjoo
Sep 21, 2006 04:31 PM
danny98r
May 18, 2005 12:31 PM
zracer240
Apr 24, 2005 08:35 AM
FalconMan
Sep 15, 2004 02:56 AM
wm5holla
Mar 23, 2003 03:39 PM
