Replacing VC gasket??
Old Aug 29, 2004 | 07:51 AM
DrewQ1's Avatar
Default Replacing VC gasket??
Hey guys i was wondering how hard is it to replace my spark plug seals and valved cover gasket on 95 Teg.
I see that theres 7 bolts to remove the VC. I'm wondering if its as easy as just putting the VC gasket over and sliding the new spark plug seal in. Are they any special tools or anything important that should be done? It looks like an easy do, but let me know, if there more to it then let me know and i'll just go ahead and have someone else do it. Thanks.
Old Aug 29, 2004 | 08:38 AM
PyroProblem's Avatar
Default Re: Replacing VC gasket?? (DrewQ1)
Its just as easy as you stated.Just remove the 10mm nuts and lift the valvecover off. Just dont flip it over without taking the little seals under the nuts or else theyll drop everywhere.
I think the helms manual calls for a dab of hondabond on the corners of the cam caps to help ensure against leakage.
Old Aug 29, 2004 | 08:47 AM
DrewQ1's Avatar
Default Re: Replacing VC gasket?? (PyroProblem)
I dont have a helms, i was just gonna do it on instinct.
Old Aug 30, 2004 | 09:42 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewQ1 &raquo;</TD></TR><TR><TD CLASS="quote">I dont have a helms, i was just gonna do it on instinct.</TD></TR></TABLE>Then be careful you don't overtighten those hold-down nuts.
Old Aug 30, 2004 | 10:08 AM
DrewQ1's Avatar
Default Re: Replacing VC gasket?? (JimBlake)
o okay thanks, but what would happen if i did?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Then be careful you don't overtighten those hold-down nuts.
Old Aug 30, 2004 | 11:13 AM
zman's Avatar
they will break....its very easy break them too....so be careful
Old Aug 30, 2004 | 11:44 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewQ1 &raquo;</TD></TR><TR><TD CLASS="quote">o okay thanks, but what would happen if i did?</TD></TR></TABLE>Then you'd get to be the 5-millionth person to post about their broken valve-cover studs.
Nicholas Bailey
Transmission & Drivetrain
May 24, 2016 01:35 PM
95-EX
Oct 31, 2012 07:48 PM
invisible
May 12, 2009 04:48 AM
nomoshing
May 19, 2008 11:51 AM
DrewQ1
Aug 29, 2004 03:59 PM
