Question about sleeves? swapping between blocks
Old Aug 27, 2004 | 09:11 AM
dunkd's Avatar
Default Question about sleeves? swapping between blocks
Can sleeves from one block be pressed out then into another block? Darton MID if it makes a difference.
Old Aug 27, 2004 | 01:51 PM
Darton Sleeves's Avatar
Default Re: Question about sleeves? swapping between blocks (dunkd)
If the sleeves were removed without damaging them you can re-use them in another block. The only thing is you would have to go to the next size piston from what they were in the block they came out of. For example if you had them at a 81mm bore in the first block you would have to go to 81.5mm on the new one.
Old Aug 27, 2004 | 05:56 PM
dunkd's Avatar
Default Re: Question about sleeves? swapping between blocks (Darton Sleeves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves &raquo;</TD></TR><TR><TD CLASS="quote">If the sleeves were removed without damaging them you can re-use them in another block. The only thing is you would have to go to the next size piston from what they were in the block they came out of. For example if you had them at a 81mm bore in the first block you would have to go to 81.5mm on the new one.</TD></TR></TABLE>
why is this? do they get slightly warped when removed?
also please check my pm to you Darton Sleeves.
Old Aug 30, 2004 | 10:05 AM
The sleeves will get a little out of round when re-installing them into another block.
Old Aug 30, 2004 | 02:34 PM
Sliced Beard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves &raquo;</TD></TR><TR><TD CLASS="quote">The sleeves will get a little out of round when re-installing them into another block.</TD></TR></TABLE>
knows his sheit
Old Aug 30, 2004 | 04:36 PM
Colin's Avatar
Default Re: Question about sleeves? swapping between blocks (DirtySol)
Can you swap stock sleeves too? And in regard to having to bore over.... do you typically need to go the full 0.5mm? or will 0.25mm over do the trick?
Old Aug 31, 2004 | 07:48 AM
Default Re: Question about sleeves? swapping between blocks (91IntegGS)
Stock sleeves are cast into the block. Yoiu might be able to go just .25 over it will depend on how out of round the sleeves get when being put back into another block. you will not know until the sleeves are installed again.
Old Aug 31, 2004 | 09:00 AM
Colin's Avatar
yeah, thats what i figured, but doesn't hurt to ask I guess Thanks.
dc2_poojan
Jun 8, 2012 07:02 AM
imptricer
Jul 3, 2007 08:24 AM
JunIntegra
Dec 12, 2003 01:15 PM
hbvetteslayer
Jun 26, 2003 08:56 PM
satan_srv
Mar 19, 2003 01:52 PM
