question about valve adjustment
Old Aug 30, 2004 | 05:35 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default question about valve adjustment
ok today i did a valve adjustment on my poormans r and now its idling really low almost ready to die down. and i also changed the plugs gap them at 36 the first time thinking that was my problem then i regapped them to .38-.39 hoping that would fix the problem but it didn't. now i'm thinking that when i did the valve adjustment i made all the valves to tight and thats whats causing my bad idle. becuase usaully i would have my friend help but i did it by my self .06 intake and .07 exhaust on ctr cams
Old Aug 30, 2004 | 07:10 PM
Default Re: question about valve adjustment (streetdreams02)
bump
Old Aug 30, 2004 | 07:24 PM
Antilag's Avatar
Did you adjust each cylinder one at a time while it was at TDC? and when you adjusted it w/ the feeler guage which side did you slide the feeler into? from the middle or from the valve side?
Old Aug 30, 2004 | 08:52 PM
Default Re: question about valve adjustment (9sech22civic)
i slided it between the rocker and the cams
Old Aug 30, 2004 | 08:55 PM
and yes i did it on tdc for each cylinder and in the correct firing order 1-3-4-2 w/ a snapon valve adjustment tool and a feeler guage but my question is if u over tighten them will they give u a rough idle
Old Aug 30, 2004 | 09:48 PM
anothersickhatch's Avatar
yes...tight valves will make your idle ****.
Old Aug 31, 2004 | 03:06 PM
Default Re: question about valve adjustment (anothersickhatch)
thank u thats what i was lookjing to hear because i was not sure if it was the valves or the new spark plugs
DaYZeD.1
Apr 19, 2008 03:07 PM
wullie_vtec
Apr 18, 2006 07:04 PM
street dreams
Aug 31, 2004 05:49 PM
HX_Guy
Nov 7, 2001 08:39 AM
