Install rod bolt with engine in car?????
Old Aug 31, 2004 | 01:56 PM
tegracer94's Avatar
Default Install rod bolt with engine in car?????
is it possible to install rod bolts when the engine is still in the car??
like from the bottom ?
Old Sep 1, 2004 | 07:24 AM
acy76's Avatar
Default Re: Install rod bolt with engine in car????? (tegracer94)
Yes, depending on the engine. I installed a #4 rod bolt in my 91 Integra with the engine in the car.
If your engine has a girdle on the mains (I *believe* all D-series have them, someone can confirm or not, and b18 vtec engines do as well...) you may not be able to get in there without removing it, which makes it trickier. You would probably have to support the crank if the girdle had to come out.
Anyway, I had to drop the exhaust, crossmember and oil pan and that was it.
Old Sep 1, 2004 | 10:22 AM
blakhatch's Avatar
iv pulled a whole bottom end of a b16 out while it was in the car (the head was off )...
Old Sep 1, 2004 | 03:00 PM
tegracer94's Avatar
Default Re: (blakhatch)
i have a B18b block so i dont think i have a gridle do u think i can do all of them?
Old Sep 1, 2004 | 06:37 PM
acy76's Avatar
Default Re: (tegracer94)
You shouldn't have a girdle (unless it's been added). You'll have to pull the oil pickup and windage tray off, but I think you should be able to access them all by turning the engine by hand (be sure not to turn it the wrong way, though - you could skip teeth on the timing belt).
Xextr3meX
Nov 16, 2015 07:17 PM
MidShipCivic
Welding / Fabrication
22
Feb 6, 2008 03:50 AM
red95integ
Aug 4, 2004 11:38 AM
SuicideSlide
Oct 11, 2003 12:20 PM
Blaze45
Oct 18, 2002 07:45 PM
