TPS adjustment .45 -.50 idle ???
I was wondering where in the .45 - .50 range would my car idle better. I have it at like .48 and it seems like my car wants to kill when i push in the clutch. and now when i go WOT from launch to 4th gear i get TPS code. I was not getting any codes before, but my throttle was acting weird, so i checked the voltage, it was .40
I can't honestly say what's best. mine's at .45 almost on the dot. Then again my car jerks around at 4-5k. While testing the TPS I noted that it had a "dead spot" where the multimeter just freaked out a little over half throttle (3.1-3.3v) so
. I'd just try to get it as close to .45 as possible and see how it goes. also, make sure that the tps has 5v going into it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote"> While testing the TPS I noted that it had a "dead spot" where the multimeter just freaked out a little over half throttle (3.1-3.3v) </TD></TR></TABLE>
you just answered your own question...get a another TPS if you need one I have one check my SIG. a dead spot would mean open circuit and you will get a DTC.
idle questions, TPS reading .77-4.55, is this enough to throw off my idle?, also my car only has 1 o
sidewayz32
Sep 30, 2005 11:34 AM
