over heating problem with motor
Old Aug 29, 2004 | 11:33 PM
slammed_93_hatch's Avatar
Default over heating problem with motor
ok i have been doing some work on my car hear and there. i finally got it all put together and started it up, it ran fine, but after a while it started to over heat. i checked the thermostat, and it was fine, alil hard to get to open, could this be the problem? the one on my other motor was ALOT easier to open, both are b series motors.
also im runing a del sol dual core rad (or something thicker then normal.
theres the radiator im running its brand new.
could it be the radiator just isn't enough for the motor? im purchasing a koyo full length radiator this week.
should i also replace the thermostat are they always pretty hard to open (with your hands).
im also gona try re doing all the fluid in the motor
Old Aug 30, 2004 | 01:58 AM
antomx's Avatar
Default Re: over heating problem with motor (slammed_93_hatch)
Not exactly sure about your engine but most honda engines have a bleed valve on the thermostat housing. If you have one you might try backing off the nut a little until coolant comes out then tightening it back up. What happens sometimes is an air pocket will form in the housing and keep the thermostat from opening.
I hope not but you could have a slight head gasket crack as well. I've seen the same problems your describing in such a situation. The crack was so fine that a compression test didnt even give a clue that there was one. But that being the last and only option, it was replaced and you could see it in the old one. It of course fixed the problem of overheating.
Old Aug 30, 2004 | 01:39 PM
Default Re: over heating problem with motor (antomx)
thanks for the advise, i really don't think its the head gasket though, the motor barily has 10,000 miles on it
Old Aug 30, 2004 | 08:37 PM
WCI's Avatar
WCI
thinking it is just that the thermo switch isnt turning the fan on
Old Aug 31, 2004 | 08:04 PM
WCI's Avatar
WCI
Default Re: over heating problem with motor (WCI)
never mind, I didnt know you already fixed that. Bump 4 more Ideas on the prob.
Old Sep 1, 2004 | 07:16 AM
up
Old Sep 2, 2004 | 01:39 AM
SivikHatch's Avatar
Check see if your fan is working. Also check the relay in the fuse box.
Old Sep 2, 2004 | 07:23 PM
Default Re: over heating problem with motor (SivikHatch)
the fan never turned on it, but it does work. what do i look for in a toasted relay
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
Ek9_Cuhzz
Sep 22, 2010 06:30 PM
r1whore
Mar 15, 2010 05:11 PM
0ne-Cam
Nov 22, 2009 10:38 PM
lude98SH
Aug 28, 2007 05:55 AM
