injector wiring issues....electricians help please!!!
Old Aug 30, 2004 | 09:00 PM
delslow94's Avatar
Default injector wiring issues....electricians help please!!!
i have dsm 450 cc injectors wired up correctly through a honda resistor box yet the box tests fine for resistance along with the injectors. my issue is that my injectors are seeing only 6 ohms each with how hondata has shown to wire it up (i know the diagrams on that site are wrong i tested for continuity) since honda injectors need to run from 10-14 ohm (obd1/2 del sol vtec) as i read in my helms but how would i be able to rewire the setup for half the ohms? i was thinking of using a 10watt 10 ohm resistor per every two injectors (ex. cyl #1 and 3 on one resistor and the other on another). do you think this would work? im very frustrated with having this as a problem and i do not know what i can do to finally get tuning done. thanks in advance and sorry it was long
marshall
GT500FTW
Nov 29, 2012 03:10 PM
bigsnorlax
May 21, 2011 01:42 PM
snowman2805
Apr 4, 2011 08:39 PM
JDMTuner4Life
Mar 7, 2007 04:56 AM
peiku
Jul 25, 2005 11:01 AM
