VAFC Question
Old Aug 29, 2004 | 07:44 PM
gamakichi77's Avatar
Default VAFC Question
i'm still blur on Vtec Unmatched settings........how can i achieve this settings?.......my chipped ECU will switch vtec at 5500rpm and i do sets my VAFC at Hi-4200rpm and Lo-3800rpm........
how can i set the Vtec Unmatched settings?
Thanks......
Old Aug 29, 2004 | 09:18 PM
87sivtec's Avatar
Default Re: VAFC Question (acidburns_di)
There is a menu on the VAFC for these settings. Check the manual. If you don't have one, you can download or view it on the Apexi site.
Why do you want your vtec settings so low? What is your setup if I may ask?
Old Aug 29, 2004 | 10:28 PM
Default Re: VAFC Question (87sivtec)
APEXi manuals didn't teach how can i sets this unmatched settings........is there any algebra calculations formula to get the corrections rate?...............
i sets my intake cams at 2deg advanced and exhausts 1.5deg advanced.
everything still stocks.......
if i sets too high, no power at all........so slow for rev up.......
help me pls...........thanks.
Old Aug 30, 2004 | 02:36 PM
unvmyS's Avatar
go to settings on the VAFC
it should be option 4 to change the settings. it's right after the option of changing VTEC.
there should be a map in your manual that shows you a generalizations of unmatched settings.
http://www.apexi-usa.com/produ...c.pdf
page 20 shows you the breakdown of functions and operations
page 33 has your generalization map for unmatched settings and how to set it
hope this helps some
Old Aug 31, 2004 | 04:59 PM
Default Re: VAFC Question (S2Kvisions)
i'm not very understand on the page 33 of that manuals........can u help me to understand it by giving some good examples......
my ECU is P30, chipped with 5500rpm.
Vafc sets at Hi-4200rpm and Lo-3800rpm
Thanks pal.......
Old Aug 31, 2004 | 07:27 PM
anybody could help me................really appreciate it
Old Sep 1, 2004 | 09:02 PM
anybody?........
Old Sep 10, 2004 | 09:16 AM
unvmyS's Avatar
just a guess, but you may want to set your unmatched settings at -1 and then try +1 if your setting vtec that low... i'm not really sure how it will work out with that... here's a run down, mayb this will help explain it.
- your chipped ecu kicks vtec in at 5500.
- you changed it to make vtec kick in at 4200
- the unmatched settings compensates from when you set it(4200), to when stock is set (5500) (4200 to 5500)
- if you view 4 items on your VAFC (put rev, vti, vto, and cor on there) vti - stock vtec vto - your set vtec from the vafc
- the vto will show on at 4200 and your correction should change to whatever you have it set at. once you hit 5500 your vti should say on and you correction should go off.
- the unmatched settings are set to help compensate for those 1300 rpms. you should try +1, then +2, then +3. my 04s kicks in vtec @6200 and i now have it set @ 5700 with unmatched settings at +2 on hi to low and low to hi
if you already knew what the unmatched settings were, i'm sorry. but i'm really tryin to help...
Rtistik.
Jan 4, 2004 01:26 AM
genetsang
Aug 20, 2003 01:54 PM
South Bay Surfer
Apr 23, 2003 03:54 PM
98R-1144
Nov 4, 2002 05:12 PM
EleanoR
Apr 17, 2002 06:06 PM
