Rod knock or lma's?
Old Aug 30, 2004 | 04:06 AM
b18bcivic's Avatar
Default Rod knock or lma's?
I have a b18c5 with a "knock"(not a ticking,more like a rattle) that starts at 2000rpms and goes faster as the revs get faster.I did the spark plug test to see if is a rod knock and the noise is still there.Wouldn't a rod knock be audible all the time and wouldn't the motor by blown by now(after dynoing and 2hr drive home from the dyno.)?any thoughts?
Old Aug 30, 2004 | 07:49 AM
JDMotive's Avatar
Default Re: Rod knock or lma's? (b18bcivic)
If it was/is a rod nock,it should be knocking all of the time,even at idle.Did you do a compression test?The rod knock would most likely be a spun rod bearing,so that cylinder would be lower in compression due to there not being a bearing and the piston sitting lower.Also,check the valve clearances to make sure there is nothing wrong in that area.
Old Aug 30, 2004 | 06:19 PM
b18bcivic's Avatar
Default Re: Rod knock or lma's? (JDMotive)
i checked the compression and it came out good,haven't checked the valves yet
Old Aug 31, 2004 | 06:35 PM
b18bcivic's Avatar
did valve adjustment and took each spark plug out revd it alittle and the sound is still there.??????????????????time to take the oil pan off i guess
Old Sep 1, 2004 | 06:36 PM
b18bcivic's Avatar
******' piece of **** ********** ************!!!!!!!!!!!!!!!!!
i fixed it maybe
Modified by b18bcivic at 11:50 AM 5/17/2005
Old Sep 1, 2004 | 07:29 PM
b18bcivic's Avatar
answer my ****** ? honda boy
preludeboybmw
Sep 29, 2010 04:21 PM
jdmboy96
18
Apr 25, 2009 11:16 AM
Chris EG
Aug 3, 2007 09:24 AM
92b16si
15
May 1, 2007 07:08 AM
Myztikal
Apr 28, 2007 07:45 AM
