* * *My How to: HOW TO RESET YOUR CLUSTER MILEAGE* * *
Old 08-27-2004, 07:39 PM
Sliced Beard's Avatar
Default * * *My How to: HOW TO RESET YOUR CLUSTER MILEAGE* * *
here is my how-to for those that want to keep their clusters at the same mileage as their chassis after a new cluster purchase
<FONT SIZE="4"><FONT COLOR="red">NOT INTENDED FOR ILLEGAL USE!!!</FONT></FONT>
<FONT SIZE="3">step one</FONT>
open your cluster by removing the face
<FONT SIZE="3">step two</FONT>
pull the face and needle off with care not to break them.......the needle may need a little coaxing with a screwdriver but they normally just come off with a tug
<FONT SIZE="3">step three</FONT>
remove the speedo unit by removing ther screws on the back of hte cluster unit (screw location may be different)
<FONT SIZE="3">step four</FONT>
remove the speedo face (again, screw location may be different)
<FONT SIZE="3">step five</FONT>
pry out on the syncro gear bar and reset dials and be sure to keep the smaller teweth inward (you will see what I am talking about when you are messing weith the syncro bar). Push the syncro bar back in, this may require a little tinkering to get everything to line up properly AND BE SURE NOT TO PULL THE SYNCRO BAR OUT TOO FAR OR THE SPRING WILL FLY OFF!!
<FONT SIZE="3">step six</FONT>
re-install needle but be sure tyo push it back on farther back fromt eh stop pin so that the spring will allow it to return completely
<FONT SIZE="3">final step</FONT>
re-assemble everything the opposite of reverse and you will have a spifftacular cluster like mine y0!!
Modified by DirtySol at 11:49 PM 8/27/2004
Modified by DirtySol at 11:55 PM 8/27/2004
Old 08-27-2004, 07:54 PM
drewbie's Avatar
Default Re: * * *My How to: HOW TO RESET YOUR CLUSTER MILEAGE* * * (DirtySol)
heheh
mrnicolas's Avatar
sweet! nice job there mr big thumbs. you did this to the cluster I sent you also right?
Old 08-27-2004, 07:55 PM
Default Re: (mrnicolas)
yup
Old 08-27-2004, 08:38 PM
dfoxengr's Avatar
Default Re: (DirtySol)
alittle bling bling for my new motor going in soon...lol
Old 08-28-2004, 01:48 AM
skunk2powered's Avatar
nice!
Old 08-28-2004, 10:48 AM
LudeyKrus's Avatar
Is there a LEGAL way to do this? Or is it pretty much illegal no matter what if you do this?
Old 08-28-2004, 11:01 AM
Default Re: (LudeyKrus)
it is not illegal if you are setting it to your chassis mileage
like if you were to buy a cluster that had a tach or a higher redline and you wanted it to show the correct mileage for your chassis
Old 08-28-2004, 03:03 PM
ScottEK's Avatar
OBD-0 Manual VSS clusters must be different.
slpr_civic93
05-15-2006 04:45 PM
g0tVTEC
05-13-2006 02:35 PM
bgod
12-17-2002 12:12 PM
bgod
12-17-2002 10:53 AM
91SIvic
11-02-2002 06:54 AM
Quick Reply: * * *My How to: HOW TO RESET YOUR CLUSTER MILEAGE* * *
