shreaded timing belt
Old Aug 28, 2004 | 07:51 PM
Boosted Chemist's Avatar
Default shreaded timing belt
i was drivng today out of the car wash and then all of a sudden my car wouldnt idle. so i get it to drive then after 4 block it just dies, i pull off and the belt is in many pieces shreaded up. My belt has 2500 miles on it and i checked it a 1000 and last night after dynoing it and was fine. Also the exhaust cam was about 75 degrees advace to the intake cam. (by the way its a b16a1) what would cause this to happen? (honda t-belt and didnt tear appart the motor yet; no garage )
Old Aug 29, 2004 | 04:44 PM
AngryTroll's Avatar
Default Re: shreaded timing belt (Mad Chemist)
Loose tensioner nut.
Loose cam bolt.
Wasted water pump
Loose bolt caught in the belt.
Basically, you screwed something up. Too bad you're not in Ohio. I'd cut you a good deal on the repairs
msminty
Engine Management and Tuning
11
Aug 28, 2010 06:51 PM
d16dcoe45
12
Nov 6, 2006 10:26 AM
pbizzlegsr
Jul 4, 2004 12:19 AM
sivik2nr
Jun 3, 2003 07:43 AM
