tailights problem
Old Aug 31, 2004 | 07:17 AM
metal-x's Avatar
Default tailights problem
one of my tailights don't work (lights don't work) when I turn my lights on
they only work when i hit the brakes, I know its not the bulbs cuz I just replaced them
i was thinking it could be a fuse ? i couldn't find any fuse's for the tailights though unless Im wrong?
any help would be apreciated
Old Aug 31, 2004 | 07:33 AM
loud_whispers's Avatar
Default Re: tailights problem (metal-x)
go find a circuit schematic for your car.
trace everything that powers exterior lighting.
there is probably a short to ground somewhere.
you can narrow out your brake light switch because we know that's working.
get a schematic, multimeter/test light and start testing ****.
if your not mechanically inclined, take it to a dealer..
first i would try looking for the obvious.. look for corroded, sliced wires, disconnected plugs etc in your trunk area..
hope i helped.
good luck
Old Aug 31, 2004 | 09:41 AM
metal-x's Avatar
Default Re: tailights problem (loud_whispers)
thanks for the reply...... I have a feeling its a faulty tailight
has anyone had a similar problem?
Old Aug 31, 2004 | 11:02 AM
JimBlake's Avatar
A short would blow fuses. I'd look for an open ground. Having a circuit diagram would be good, too.
Old Aug 31, 2004 | 02:48 PM
IVI's Avatar
IVI
it could be a short, or also, there are diffrent types of tail light bulbs. some have 1 filament, some have 2. make sure you put the right kind of bulb in there.
Old Aug 31, 2004 | 09:33 PM
metal-x's Avatar
Default Re: tailights problem (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">it could be a short, or also, there are diffrent types of tail light bulbs. some have 1 filament, some have 2. make sure you put the right kind of bulb in there.
I've swaped bulbs from the working tailights and have the same problem
Old Aug 31, 2004 | 09:36 PM
mmuller's Avatar
Mad Scientist
check for grounds
Old Sep 2, 2004 | 01:48 AM
SivikHatch's Avatar
Does your license plate light come on?
Old Sep 2, 2004 | 05:50 AM
metal-x's Avatar
Default Re: tailights problem (SivikHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SivikHatch &raquo;</TD></TR><TR><TD CLASS="quote">Does your license plate light come on?</TD></TR></TABLE>
Yes
Old Sep 8, 2004 | 03:59 PM
metal-x's Avatar
problem solved turned out to be a lose wire on the tailight
thanks all for the help
boush95ls
Apr 30, 2009 01:42 PM
accordinglyevil
May 1, 2007 07:22 PM
themex77
11
Jun 21, 2006 06:21 PM
im done
Nov 12, 2004 08:52 PM
rated_r
Apr 10, 2003 09:29 AM
