causes of lower fuel cut / rev limiter?
Old Aug 31, 2004 | 07:57 PM
Driven's Avatar
Default causes of lower fuel cut / rev limiter?
Engine: B18C1 in a CRX
Electronics: Fields VTEC Controller (NOT connected to the map sensor)
Fuel: B&M Adjustable FPR; B&M Fuel Pressure gauge at 42psi@WOT.
Problem: sometimes, it'll rev to 8200rpm in first, then second and higher gears will only go to 6200rpms.
I'm thinking it's cause it's not getting out of closed loop. but, what would cause that?
I'm running a new O2 sensor (properly wired) and fuel pressure is showing good.
What else should i be checking that i haven't?
Old Aug 31, 2004 | 08:36 PM
sol_guy8569's Avatar
Default Re: causes of lower fuel cut / rev limiter? (Driven)
are you throwing any codes?
Old Sep 1, 2004 | 06:19 AM
Driven's Avatar
Default Re: causes of lower fuel cut / rev limiter? (sol_guy8569)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_guy8569 &raquo;</TD></TR><TR><TD CLASS="quote">are you throwing any codes?</TD></TR></TABLE>
no codes.
i'm thinking it might be fuel pressure related... I'll be playing around with fuel pressures later to see if it'll remedy the issue.
Old Sep 1, 2004 | 12:36 PM
I would say that that might be the problem.
onefstek
Nov 18, 2005 01:55 PM
baby50
Oct 11, 2005 07:50 AM
importimage
Jul 12, 2003 11:06 PM
CRX A4
10
Jun 1, 2003 09:20 PM
