under the valvecover.
Old Aug 28, 2004 | 07:38 PM
89s1's Avatar
Default under the valvecover.
today I was in my garage, idling my car, and the two outer-rear valvecover nuts/washers were not in, I was just runing it for a while and then might have needed to take it off, so i only used 6 oof the 8
the thing is... I was getting a smoke being pumped out in bursts, a steady stream, but puff puffing, if you know what I mean.
I'm just wondering if all that smoke under the valvecover is normal, and does it usually just get sucked out by the intake when she's sealed? and in the case of a breather, I'm guessing it would just force it's way out the filter element?
I did a search but 'valve cover' got me like 652 topics
Old Aug 28, 2004 | 11:02 PM
Proglow3's Avatar
Default Re: under the valvecover. (89s1)
It's normal for you oil to get hot and start to become vapors. If your seeing vapors while your valve cover is tightened down then I would think that your valve cover gasket it leaking and needs to be replaced. I think I need a little more explanation on what's really going on.
el3vate
Nov 27, 2004 10:34 AM
mulpha
Jan 14, 2004 04:01 AM
boostdB16a
Aug 8, 2003 08:28 AM
Cryptopsy
Feb 1, 2002 07:27 PM
