i need OMNI pOwER adviCE!
so i was checking out the new all time favorite OMni POWER! i hear REALLY good things about it...you know what i havent heard anyone talking **** about it...but yea...i was sad to see that they only have set-ups or only 92-AND UP! wtf...ok...here is my problem...i want that set up...but i dont know what i would have to do in order to convert my 89REX to fit that set up...any HELP please guys...i want that set up...any ADVICE?
You could always PM Omniman and see what he says, but you should know that EF/DA suspensions are somewhat interchangeable with EG/DC suspensions. You will need new front drop forks from an EG or DC2/DC4/DB8/DB7 (92-95 civic, 94-01 integra). They cost around $50 brand new, each, but you could probably get them from a junkyard or used from someone for less. If you use DC/EG omnis and EG/DC front forks, it will bolt up fine. The rear EG/DC and EF/DA suspensions are basically the same (only the shock is actually longer and thinner), but it will bolt up perfectly.
I have heard that people with 90-93 tegs who use EF parts usually end up with a very low car. So, conversely, your car may be a little high at first, but the coilovers should clear that right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neoclown1 »</TD></TR><TR><TD CLASS="quote">so i was checking out the new all time favorite OMni POWER!</TD></TR></TABLE>"OMFG Steam Roxorz Teh BIG ONE111!"
BTW Omniman makes some good stuff
Ssaacckkeedd
Mar 24, 2007 09:13 PM
Integra_B18B
Dec 1, 2004 06:47 PM
