Need help ASAP!!!
Old Aug 29, 2004 | 12:07 PM
98JDM_Type_R's Avatar
Default Need help ASAP!!!
Well I tried putting my 95 B18C swap into my 00cx yesterday, and ran into a whole load of different problems. My biggest problem is the distributor. I did a search but didn't find any that could help me.
I tried to repin my distributor, to find out that OBD2b D16y7 clip is no different than an OBD1 clip. So, I had to rewire my harness to fit the distributor. To my surprise the colors are not the same between the 00si harness and the OBD1 distributor harness.
Does anyone have the color codes for the distributor and the harness?
Also, for the extra plug on the distributor that has two wires. The SI harness only has the Black/Yellow wire, and does not have the Blue. Does this affect it in any way?
For those of you trying this swap, you will also need a GSR fuel line (not fuel rail) and throttle cable.
Fastwhip
Apr 9, 2006 02:26 PM
MoogieBoogie
Aug 5, 2005 06:30 PM
vxnine
Jul 25, 2005 05:49 PM
98JDM_Type_R
Aug 30, 2004 07:57 AM
