nedd help with ngk plug wires
Old Aug 29, 2004 | 04:41 PM
Innovative LS's Avatar
Default need help with ngk plug wires
I have a set of the Beru Silverstone spark plugs (nology) and I am using the Ngk sport plug wires (Blues) and top of the Beru plugs came off in the plug wires. So I purchased the Ngk v power plugs and replaced the Beru plugs but I had to use two of the original OEM Sumitoma plug wires and noticed that the OEM wires had clean boots while the ngk plug wires had lots of black and brown dust on them as well as the Beru plugs. Then while installing the plug wires I noticed that the OEM wires were seating better to valve cover. I was wondering if the the lack of seal on the Ngk plug wires where contributing to the dust accumulation or if the dust was normal wear and tear, and if i should clean spark plug holes? Thanks
Old Aug 30, 2004 | 07:23 PM
Default Re: need help with ngk plug wires (Innovative LS)
bump
OrangeTeggy
Apr 4, 2009 12:43 PM
Innovative LS
Aug 30, 2004 08:25 PM
b16ahybrid
Feb 18, 2003 02:19 PM
