Coolant Temperature Sensors - 91LS and 95LS - Do they operate the same??
Old Aug 31, 2004 | 06:36 PM
Tryk's Avatar
Default Coolant Temperature Sensors - 91LS and 95LS - Do they operate the same??
I posted this in the Integra forum but have not received any answers... lets see if anyone in the tech forum can answer my question.....
Hi gang,
I am putting a 95LS engine into a 91 integra. It is going good so far but I have run into a problem where the coolant temperature switches to turn on the fan are different for both engines. The sensor on the 91LS engine is located in the back of the block above the oil pressure sensor, and the sensor off of the 95 engine is located in the thermostat housing.
They are different threads and I can't just put the 91 sensor in where the 95's sensor is. Also I can't find any metric fitting adaptors anywhere in this city. So my question is if the 2 sensors operate the same way. Do they both just open the circuit at a certain temperature? If so I am sure I can just rewire the harness to use the 95 sensor.
Any input would be appreciated. Thanks in advance!
Old Aug 31, 2004 | 07:08 PM
mmuller's Avatar
Mad Scientist
Default Re: Coolant Temperature Sensors - 91LS and 95LS - Do they operate the same?? (Tryk)
just lenghten the wires and use the obd1 one
mario456
Apr 6, 2013 10:03 PM
ef_hopeful
Apr 16, 2010 01:47 PM
alexm
May 17, 2008 08:42 AM
