LOW IDLE AFTER CAR WARMS UP
Old Aug 31, 2004 | 02:56 PM
Layziebtnh055's Avatar
Default LOW IDLE AFTER CAR WARMS UP
when i first start my car in the monmring the idle is at about 2000 for a couple minutes then it idles fine at 850, after driving for a couple minutes i let go of the gas and the idle drops, the car shakes like hell, kinda like it wabnts to stall, does anyone have any ideas?? I tried cleaning the iacv, i am getting a cel for the tps, would that make the idle bad....
Old Aug 31, 2004 | 04:29 PM
sol_guy8569's Avatar
Default Re: LOW IDLE AFTER CAR WARMS UP (Layziebtnh055)
the tps would make it do that as far as I know.
Old Aug 31, 2004 | 05:46 PM
Default Re: LOW IDLE AFTER CAR WARMS UP (sol_guy8569)
Sorry, I'm not authorized to use the I.M. fo rsome reason.
The only place I know to get one is through Honda.
Unless you can find one on the Net somewhere.
Old Aug 31, 2004 | 09:28 PM
anothersickhatch's Avatar
check your valve clearances...valves may be to tight and may be in need for a valve adjustment.
Old Sep 1, 2004 | 02:38 AM
eg6T's Avatar
Default Re: LOW IDLE AFTER CAR WARMS UP (anothersickhatch)
mine idled gay...it was the tps..check the volts on it,should be .5,mine was at like .2 or something
Junkyard2000
Sep 14, 2005 07:07 PM
Grnade
May 30, 2005 10:18 AM
Layziebtnh055
Aug 31, 2004 03:07 PM
