Shakey Idle PLEASE HELP
Old Aug 30, 2004 | 06:03 AM
Layziebtnh055's Avatar
Default Shakey Idle PLEASE HELP
when i first start my car up in the monring it idles fine, its seems like after the car warms up the idle goes down a little and the car shakes when im stopped any ideas
Old Aug 30, 2004 | 05:52 PM
Default Re: Shakey Idle PLEASE HELP (Layziebtnh055)
bump
Old Aug 30, 2004 | 08:31 PM
EK22snatch
Guest
Posts: n/a
well, im pretty sure this is thanks to honda's optimal fuel efficient computer, but im not sure what actually does this though. i noticed it earlier this spring, but now its seemed to go away.
bump cuz im a bit curious to know now too
Old Aug 31, 2004 | 06:57 AM
Default Re: Shakey Idle PLEASE HELP (EK22snatch)
could my iavc be clogged?
Old Aug 31, 2004 | 07:52 AM
JimBlake's Avatar
Maybe your IACV. Also maybe you need to set your base idle speed correctly?
Old Aug 31, 2004 | 01:29 PM
eK9aT10pSi's Avatar
Default Re: Shakey Idle PLEASE HELP (JimBlake)
i have the same issue in my 99 civic ex. how do you set the base idle? ive heard that your supposed to start the car, get it warmed up and when the radiator fan comes on, disconnect the IACV and the idle should drop to base rpms. but the thing with mine is that it doesnt drop at all.
Old Sep 1, 2004 | 03:28 AM
JimBlake's Avatar
Default Re: Shakey Idle PLEASE HELP (eK9aT10pSi)
The procedure for my '95 integra is just like you say. Other years might not be exactly the same. You gotta find a shop manual for your car.
Old Sep 1, 2004 | 07:36 AM
Jimmy's Avatar
Global Moderator
Buy the haynes manual@!
Tinoo
10
Feb 20, 2011 03:46 PM
georgiajdm
Aug 11, 2009 06:31 PM
94hondacivicvtec
Dec 7, 2008 12:44 AM
brad98_teg
Nov 10, 2006 01:30 PM
daddymaxx
Dec 15, 2003 12:24 PM
