Just bigger injectors a performance mod?
Old Sep 1, 2004 | 11:26 AM
Elemental's Avatar
Default Just bigger injectors a performance mod?
I started gathering my parts for my turbo setup. I got some rc engineering 550cc injectors.
I rememeber I read in honda high performance handbook that bigger injectors are a good way to increase hp on an otherwise stock application.
well i cant find my book to make sure. Are they going to help me on a stock b18b1?
thanks a lot
Old Sep 1, 2004 | 11:28 AM
tgreaves's Avatar
Default Re: Just bigger injectors a performance mod? (Kyoushu)
I dont see how.. If your getting the correct air/fuel ratio with the stock injectors then that shouldnt change when going to bigger ones.. Also remember, you need to find a way to pulse the bigger injectors slower..
You CANT just put them into your stock car with a stock ecu and have them work correctly..
Modified by tgreaves at 3:44 PM 9/1/2004
Old Sep 1, 2004 | 11:38 AM
Elemental's Avatar
Default Re: Just bigger injectors a performance mod? (tgreaves)
can or cant?
either way i wont put them on then. i figured it wouldnt, but i might give it a shot.
Old Sep 1, 2004 | 11:45 AM
tgreaves's Avatar
Opps.. I fixed it.. you CANT put them on a stock ecu unless its chipped or otherwise modified..
Old Sep 1, 2004 | 12:04 PM
Sack Master's Avatar
Bigger injectors CAN increase horsepower on a stock application SOMETIMES. But 550s are just too big.
Old Sep 1, 2004 | 12:10 PM
JerseySiPOS's Avatar
Default Re: Just bigger injectors a performance mod? (Sack Master)
you have to find the happy medium between fuel pressure and fuel flow.
with a stock ecu and injectors that big, you wont even be able to start the car.
Old Sep 1, 2004 | 12:14 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Bigger injectors CAN increase horsepower on a stock application SOMETIMES. But 550s are just too big. </TD></TR></TABLE>
Only way I can see this happening is through efficiency..
Old Sep 1, 2004 | 10:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Only way I can see this happening is through efficiency..</TD></TR></TABLE>
That is correct
Old Sep 2, 2004 | 06:05 AM
tgreaves's Avatar
That is correct</TD></TR></TABLE>
Ahhh..
all-mtr-teg
Apr 16, 2007 08:32 PM
Red_Si
Oct 27, 2006 04:05 AM
vteczone
Nov 29, 2004 05:23 AM
Octoman
Jun 19, 2004 10:36 PM
