OBD-2 JDM GSR Motor Question
Old Aug 29, 2004 | 08:20 PM
Boost2NA's Avatar
Default OBD-2 JDM GSR Motor Question
Does this motor come with a crank angle sensor. I have been told that they do not but I wanted to verify before I order this ECU. My problem is I have a OBD-1 motor running off a OBD-2 ECU and I am getting a Code 54 (crank angle sensor). I want to keep my car OBD-2 and if I can order a JDM OBD-2 ECU to solve the problem then thats what I will do. I really would like to keep the car OBD-2 but if I have to I will just get a conversion harness and go back to obd-1. Thanks everyone.
Old Aug 30, 2004 | 05:06 PM
Boost2NA's Avatar
Default Re: OBD-2 JDM GSR Motor Question (Boost2NA)
bizump
Old Aug 30, 2004 | 05:48 PM
aj99si's Avatar
Japanese OBD 2 motors are basically obd 1 with obd 2 connectors. My 97 jdm type r came with no crank fluctiation sensor CKF and only has one oxygen sensor. CKP TDC CYP are all sensors in the distributor.
Old Aug 30, 2004 | 05:50 PM
aj99si's Avatar
Default Re: OBD-2 JDM GSR Motor Question (aj99si)
code 54 is CKF not crank angle.
joshd_bh
Sep 5, 2012 08:14 PM
wascly
Jun 20, 2007 10:33 PM
Boost2NA
Aug 29, 2004 08:15 PM
jeremy.
Aug 22, 2003 07:06 AM
Civic DX 4dr
Jun 26, 2003 11:27 PM
