Slipped timing belt help!!!!!!!!!!!!!!
Old Aug 28, 2007 | 01:23 PM
sherdog9's Avatar
Default Slipped timing belt help!!!!!!!!!!!!!!
car was runing at 10mph and started to shut down with several backfires. The guy at gas station told me it's posible of slipped timing belt. How hard to fix it? i am about to change my timing belt tomorrow ........ please help.
Old Aug 28, 2007 | 01:32 PM
TooManyTickets's Avatar
Default Re: Slipped timing belt help!!!!!!!!!!!!!! (sherdog9)
Timing belts dont ussualy slip. they are a toothed belt so it is possible the tensioners is loose and it skipped a tooth or two but timing belts dont slip.
Old Aug 28, 2007 | 01:34 PM
sherdog9's Avatar
Default Re: Slipped timing belt help!!!!!!!!!!!!!! (TooManyTickets)
does it affect the head at all? I need to get it fix so i can drop my car off for timing belt change
Modified by sherdog9 at 2:46 PM 8/28/2007
Old Aug 28, 2007 | 04:29 PM
sherdog9's Avatar
someone?
Old Aug 28, 2007 | 04:37 PM
unless its "slipped" so many teeth that the vavles come in contact with the pistons then you should be fine with respect to the head. it sounds as though, it is off several teeth and will need to be replaced and the timing correctly set.
Old Aug 28, 2007 | 07:28 PM
sherdog9's Avatar
^^thanks a bunch man. I'll see what they say tomorrow.
Old Aug 28, 2007 | 10:36 PM
Rd91SiB18ls's Avatar
MY civic did that twice it was the distributor rotor bolt fell out
check that and pull off the timing belt cover and inspect the belt.
I lock tighted the threads on the rotor bolt and it never happened again.
good luck
Old Aug 29, 2007 | 07:30 PM
sherdog9's Avatar
Default Re: Slipped timing belt help!!!!!!!!!!!!!! (Rd91SiB18ls)
^^darn you're the man......... it was distributor/rotor problem....got it fixed.... not sure if the guy applied some thread lock to it.
Old Aug 29, 2007 | 11:42 PM
Glad to see it was something simple
ej1252
Jan 16, 2010 10:22 AM
DETALZ
Aug 6, 2007 10:53 AM
GSRpower
Dec 30, 2002 08:16 AM
