Engine building tools?
Old Aug 23, 2007 | 08:49 PM
1zach4's Avatar
Default Engine building tools?
I'm picking up a b18a block to build because i'm not really sure how long the b18b1 block in my civic will last due to buying it from someone I used to respect, but now not so sure about.
I am going to get this thing sleeved and bored to 2.0L no matter what, but still not sure when it will get boosted, so I need to know what tools I will need in order to build it myself
So far I have looked @ getting the following:
- Piston ring filer
- Ring installer
- Ring compressor
- Feeler gauges
- Torque wrench
- Plastigage
- Dial bore gauge
- Digital caliper (0-6in. accurate to .001)
- Rod bolt stretch gauge
- Telescoping gauge kit
I was looking @ micrometers, but they are expensive and from what I understand so far, the plastigage and digital caliper should compensate for the micrometers.
Is there anything else I might need?
Old Aug 23, 2007 | 08:54 PM
ekb16's Avatar
http://www.k20a.org/forum/showthread.php?t=31496
Old Aug 23, 2007 | 09:05 PM
1zach4's Avatar
Default Re: (ekb16)
thanks for the link
looks like I need micrometers, but from other research it looked like I needed 0-5 in. micrometer sets, but that link says 0-3 which is much more affordable
Old Aug 23, 2007 | 09:08 PM
1zach4's Avatar
Default Re: (1zach4)
also after reading that thread do I really need feeler gauges, and a telescoping gauge kit?
Old Aug 23, 2007 | 09:13 PM
ekb16's Avatar
feeler gauges are used to measure your piston ring end gaps and telescoping gauges are use to measure the ID of your piston rod ends and other things
Old Aug 23, 2007 | 09:44 PM
TooManyTickets's Avatar
Default Re: Engine building tools? (1zach4)
*****- Dial bore gauge/torque wrench **** excellent... these are your best friend and dont forget it
you may also want to invest in a quality set of micometers
0-3 is good.. but idk if u can find a set of only 3?
Old Aug 23, 2007 | 09:53 PM
1zach4's Avatar
Default Re: Engine building tools? (TooManyTickets)
found a set of 0-1, 1-2, and 2-3 on summitracing
Old Aug 23, 2007 | 10:49 PM
BILLETGRIP's Avatar
page 1249 in the big MSC book. starrett .0001 grad. 0-1 $176.00,
1-2 $217.00, 2-3 $242.00, 3-4 $274.00, 4-5 $289.00, 5-6 $302.00, 6-7 $319.00.
Being a machinist gets expensive. If you dont plan on making a living measuring stuff i wouldnt go out and buy any mics. just take it to a machine shop and let them do it.
Old Aug 24, 2007 | 12:09 AM
turbod da's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.k20a.org/forum/showthread.php?t=31496</TD></TR></TABLE>
Old Aug 24, 2007 | 05:44 AM
1zach4's Avatar
Default Re: (92gs)
im not planning on making a living do it, but my brother, friends of mine, and myself are all into hondas so the more I learn about rebuilding an engine, the better off we all will be in the end
Old Aug 24, 2007 | 11:54 AM
Darton's Avatar
You also need a good hammer for those real tight tolerances...
Old Aug 25, 2007 | 03:32 PM
Lubo_25's Avatar
everything on that list looks good to go man except for those telescoping gauges they are not to be used on building these motors thats a complete joke...get a nice set of .0001" incremented micrometers(if its out of the budget wait a little and save some cash) and a good dial bore gage also reading into the .0001" increments for your cyl. bores, rod end bores, etc. nothing less then that tolerance for tools should be used for measuring clearances and checking...calipers will never replace mic's...and when you buy the rod bolt stretch gage get a 2 lb. spring or higher it will stay on the bolt nicer and not give out inaccuracies...just my .02 cents
B_Swapped93
16
Nov 18, 2013 03:40 PM
Civicman86
Sep 23, 2008 04:49 PM
The Destroyer
14
Sep 9, 2007 07:11 AM
1zach4
Aug 23, 2007 10:47 PM
